Removing Old Versions of Office
Mennochio
Post by Mennochio »
I have the professional versions 2016, 2018 & 2021 all installed on my Windows 10 machine. Can I remove the 2016 & 2018 versions without impacting the 2021 version?
Re: Removing Old Versions of Office
Yes, you can remove SoftMaker Office 2016 and 2018 without any problem.
You may get some small problem like equation editor disappearance post the installation, which you can solve (if you get such problem) by running repair installation of SoftMaker Office 2021.
