Textframe object loses it's shape
justin
Post by justin »
Hello, I have an issue where I want all the text frame objects in the slide design to have rounded edges. I can round the edges in Slide Master view, but when I return to the standard view and add a new slide the new slide has square edges.
Slide Master View
Slide Master View
Slide Master View
Standard View
Standard View
Standard View
PS: It's really awesome to be able to use this software on Linux. Thank you! Also it's really nice to have Korean language support!
Re: Textframe object loses it's shape
Thanks for reporting this problem. We are able to reproduce it and forwarded the details to our developers team for further investigation.
Our developer team has fixed this problem and the solution will be included in the next service pack of SoftMaker Office.
