Installation Error on OpenSuse Tumbleweed
vtpoet
Post by vtpoet »
I've always used Debian based systems since RedHat went "commerical", but I wanted to try a rolling release and thought I'd give Tumbleweed a try. While installing Softmaker Oifice I got the following complaint. I chose to Ignore. Not being as familiar with Tumbleweed or RPM management, wasn't sure how crucial this was. I'm guessing that it means there won't be any automatic updates via the repository?
Code: Select all
sudo zypper install softmaker-office-2021-1034.x86_64.rpm
[sudo] password for root:
Loading repository data...
Reading installed packages...
Resolving package dependencies...
The following NEW package is going to be installed:
1 new package to install.
Overall download size: 277.0 MiB. Already cached: 0 B. After the operation, additional 661.2 MiB will be used.
Continue? [y/n/v/...? shows all options] (y): Y
Retrieving package softmaker-office-2021-2021-1034.x86_64        (1/1), 277.0 MiB (661.2 MiB unpacked)
softmaker-office-2021-1034.x86_64.rpm:
    Header V4 RSA/SHA256 Signature, key ID aa3e7f5e: NOKEY
Looking for gpg key ID AA3E7F5E in cache /var/cache/zypp/pubkeys.
Repository Plain RPM files cache does not define additional 'gpgkey=' URLs.
softmaker-office-2021-2021-1034.x86_64 (Plain RPM files cache): Signature verification failed [4-Signatures public key is not available]
Abort, retry, ignore? [a/r/i] (a):
vtpoet
Re: Installation Error on OpenSuse Tumbleweed
Post by vtpoet »
FYI:
Code: Select all
sudo rpm --import linux-repo-public.key
error: linux-repo-public.key: import read failed(2).
vtpoet wrote: Sun Aug 01, 2021 6:16 pm FYI:
Code: Select all
You need to add the path to the file linux-repo-public.key, wherever you stored it. For example:
sudo rpm --import /home/vtpoet/linux-repo-public.key
