Import Style
jmarc
Import Style
Post by jmarc »
Sometimes I want to update a current document that is based on an old template or no template at old.
The best way to do that should be to import the paragraph style and character style from a template or another document.
Is ther a way to do that? If not, don't you think that could be a nice feature in the next releases ?
Re: Import Style
Whenever you copy any text from one document to another, the associated paragraph/character style also import with that.
You can also copy styles between documents using our style manager.
