Hyphenation Setup
G.R.H
Hyphenation Setup
Post by G.R.H »
Hello,
Is there a way, please, of setting 'no hyphenation' as the default setting for all new documents to obviate the need to do it per document.
Thanks in advance.
Re: Hyphenation Setup
Post by Jossi »
Go to File > Open, choose file type "Templates (*.tmvx, *.tmv)" and open Normal.tmvx (the default template for all new documents). Deselect "Automatic hyphenation" in the "Tools" menu. To be on the safe side, go to Format > Paragraph styles, choose "Normal", click "Edit...", tab "Text flow", and change "Hyphenation" to ""None". Click "OK", then "Apply" and save the template with File > Save. All future documents based on this template will have no hyphenation.
G.R.H
Post by G.R.H »
Thank you.
