Downgrade to older versions
crevette
Post by crevette »
Hello.
I have purchased SoftMaker Office Professional 2021. I wanna downgrade it do SoftMaker Office Professional 2016. Is there a way to do it? If yes, how to do it?
Re: Downgrade to older versions
Downgrade of SoftMaker Office 2021 is not possible as SoftMaker Office 2016 is very old.
If you have purchased SoftMaker Office 2016 in the past, then you can install it and activate it using the given product key.
