how to disable Document Tabs
tom617
Post by tom617 »
Is there a way to disable Document Tabs in Textmaker 2021? Document Tabs to me are not necessary, and they use up a valuable strip of space in the Toolbar area. Thanks
Re: how to disable Document Tabs
You can't disable document tabs.
At least with ribbons, disabling them would not save space, since the tabs share their space with the Quick access toolbar.
tom617
Post by tom617 »
Thanks for the reply! I don't use ribbons in any program. Never liked them. I'm thinking there may be some way in TextMaker coding to disable Document Tabs as they do not show in the 2018 Free version. Tabs are superfluous, and the strip of space they take up across the top of the screen is significant.
To check the feasibility, I have forwarded this request to our product management...
tom617
Post by tom617 »
Many thanks for checking into feasibility for this. I actually use TextMaker mostly on a Mac (I purchased the 2021 license for this), so if this can be considered for the Mac platform as well, it would be much appreciated.
