Export Rubbon Customisation
jmarc
Post by jmarc »
I foud the customisation of rubbons a very usefull feature. Anyway, I miss the possibilty to export and import my own rubbons in order to save them and retrieve them, when I want to do a fresh (re)-install on the same or a new machine.
I think this possibility could be a good improvement.
Re: Export Rubbon Customisation
Thanks for your feedback. You can copy the tmw21tools.dat file from your SoftMaker/Settings folder, keep it as backup or paste it on the destination computer where you want to import the customization.
jmarc
Post by jmarc »
Thank you for the the trick!
Anyway, an integrated feature should be an improvement of the application.
Thanks for your suggestion. I have forwarded this feature request to our developers team.
stascheit
Post by stascheit »
There is now a feature for import/export certain settings.
See Manual
