I open an .xlsx file from my Google Drive within PlanMaker. I make changes to the file and tap the Save icon. The file updates.
When I attempt to access the file from my Windows PC, the shortcut says the file does not exist. When I look in Google Drive on the PC, (1) has been appended to the file name, and the original file is gone. The "(1)" file does contain the latest updates.
I don't see anything in the Files tab of the Options screen of PlanMaker in Android that says anything about changing the file name. I have "no backup" selected and auto-recovery turned off.
File Name Changes when updating File on Google Drive
Re: File Name Changes when updating File on Google Drive
Thanks for reporting this problem. Please let us know if this problem happens only with this file and this time only or with other files also?
Also, share your sminfo file which you can generate by clicking on '?' > About > Write system information.
After several tests, the (1) on the file name appears to have gone away. I did make it happen earlier with more than one file stored on Google Drive. But I discovered that my original post was not accurate. I have two devices and was mixing the settings that I reported.
If I change the backup option to "no backup", files do not save, even tho I see the message "transferring data". It was after turning backups off and on that the (1) on the file name went away and files started saving again.
I've attached the sminfo files for each device. Please let me know if I can provide any additional info or try anything else for you. Thanks!
- sminfo Kindle Fire.txt
- (47.51 KiB) Downloaded 5443 times
- sminfo Android 10 phone.txt
- (72.58 KiB) Downloaded 5541 times
Thanks for sharing the details. So now, your files are saving normally without additional (1) even when backup is enabled?
Files are saving normally Only when backup is enabled. If backup is not enabled, the file doesn't save at all, even though I see the message "Transferring data...".
Did you open the file directly from Google Drive or from PlanMaker File | Open ? Please let us know how you opened the file?
From PlanMaker File | Open
And the (1) file name unexpectedly appeared again. I didn't pay attention to the sequence of events, because I thought that issue had gone away.
Thanks again for looking into this!
Thanks for sharing the information. I am unable to reproduce this adding (1) to file name problem, but I have forwarded the details of both the problems to our developers team for further investigation. I will let you know if any further important information will be required from you.
Our developer team has fixed this problem and the solution will be included in the next update of SoftMaker Office 2021 for Android.
Thanks very much!
