Subscription Issue
razazaidi1
Subscription Issue
Post by razazaidi1 »
On 03 May 2021 I had entered a subscription monthly as I wanted to use the Print Function which is not available on the free version
Today after an update of PlanMaker when I entered Print then PlanMaker opened the dialog box asking for subscription
My complaint is that once I have subscribed and the subscription period is not over yet why I need to pay again
Re: Subscription Issue
If you received an update today, you are still in the beta program and should leave it. Subscriptions don't work inside a beta test.
Instructions for leaving the beta: https://www.softmaker.com/newsletter/n. ... 1-05-16-en
razazaidi1
Followed your suggestions and everything is okay now
Must say an excellent program and an even better support team
Thanks for your help
Regards
Return to “PlanMaker 2021 for Android”
