Audio files stop and restart
BobFormby
Post by BobFormby »
I have an audio files running in the background while slides are being shown. Is there a way of temporarily pausing it and then restarting or do I have to use an audio editing tool to divide it into two and run each file separately behind their set of slides?
Thanks.
Re: Audio files stop and restart
Currently, we don't have this feature, so as you mentioned you can edit your audio file.
Return to “Presentations 2021 for Windows”
