Installed SoftMaker Office 2021 & 2012 Is Still Installed
Winterfall
Post by Winterfall »
I had an older version of SoftMaker Office 2012 Pro installed and assumed the 2021 installer would uninstall it. Since it did not i have two questions:
1. Does it matter if I leave the 2012 version installed?
2. Can I uninstall 2012 with no issues happening to the new 2021 version of SoftMaker Office?
Thanks!
Re: Installed SoftMaker Office 2021 & 2012 Is Still Installed
Post by Jossi »
Different versions of SoftMaker Office can be installed side by side.
There is no risk if you leave SMO 2012 installed.
There is also no risk in uninstalling SMO 2012 as both versions use different settings, templates and so on.
