More issues with styles and ODF
lgsl
Post by lgsl »
When opening a ODF file in TM 2021, under "Styles in use" are shown a list of styles that do not reflect the reality of the document.
This issue can be seen/reproduced as follows:
1. Create a new document in LibreOffice. (Notice that the only style in use is "Default Paragraph Style")
2. Save the document as is. No typing is required.
3. Load document in TM2021. (TM reports that 10 different styles are in use, including Index styles. Only "Normal" should be in use.)
Re: More issues with styles and ODF
In TextMaker the filter "Styles in use" means the styles which are applied in the document as well as defined in the document but in LibreOffice Applied Style filter showing only applied. So, both are different things.
lgsl
Post by lgsl »
OK. So could be then this filter be implemented in TextMaker?
Thanks for your suggestion. I have forwarded this feature request to our developers team.
