High CPU usage
lgsl
High CPU usage
Post by lgsl »
The same problem as reported here: https://forum.softmaker.com/viewtopic.p ... 829#p69829
Keep in mind this has been detected in different machine with a quite different hardware configuration. I would even dear to say this is even easier to detect in the MacOS version of TM, that it's in Linux.
Re: High CPU usage
Thanks for reporting this problem. Please share the associated file of TextMaker 2021 in which you are getting this problem and a screen recording of the problem so that we can do further investigation for resolution. Also, share your sminfo file which you can generate by clicking on '?' > About > Write system information.
viewtopic.php?f=386&t=21074
lgsl
Re: High CPU usage
Post by lgsl »
I sent the requested information via email
Re: High CPU usage
Thanks for sharing details. I have checked your Linux video and found its fine if for some instant CPU usage reached 16-19% while you are typing with spell checker etc. enabled.
