I can't print more than one copy of single document
MVR270
Post by MVR270 »
Details:
O.S. linux Mint 19,3
After the first installation everything worked correctly, but from a certain point on, I don't know exactly when, it was no longer possible to print more than one copy of the open document, both plan and text, if I put the same number of copies in the printing phase to 2 or 3 only one copy is printed.
Both the operating system and the suite are updated to the latest release available
thank's for the help
Re: I can't print more than one copy of single document
Please try to completely reinstall your printer driver with the latest version available and let us know if that work for you.
MVR270
Post by MVR270 »
All right now its ok
thanks a lot
