Softmaker's animations stopped working
HistoricExp
Post by HistoricExp »
Hello -
One day while trying to create a new presentation, when I went to animations, all the ones marked "Softmaker" had stopped functioning, and are instead replaced with a quick fade. All the animations that mimic Powerpoint -- dissolve, checkerboard, pinwheel, et al -- they function just as before. But the ones that are unique to Softmaker -- comet, balloons, tornado, so on -- do nothing except fad into place. This is true for Appear, Emphasize, and Disappear. Any thoughts? Help!
Re: Softmaker's animations stopped working
Thanks for reporting this problem. Please share the associated file of Presentations 2021 in which you are getting this problem so that we can do further investigation for resolution.
viewtopic.php?f=384&t=21033
HistoricExp
Sorry for the delay - lots going on!
So the problem is not limited to one file. It happens every time I try to add a Softmaker animation.
I am sharing a Loom recording of the problem in action on a new presentation.
I hope this clarifies my difficulty.
Many thanks for your thoughts.
https://www.loom.com/share/0aa7751486f3 ... 04f37a10d0
Thanks for sharing the screen recording, I tried this problem but unable to reproduce it. SoftMaker animations worked fine as defined.
Please close SoftMaker Office apps, rename SoftMaker folder which is in Documents and then try to reproduce this problem again. If required please reinstall SoftMaker Office 2021.
Return to “Presentations 2021 for Windows”
