Over sized New document windows
lgsl
Post by lgsl »
In TextMaker and Presentations when you open the dialog to create a new document, the window to choose a new template is over sized. it does not fit the screen and can not be resized. Due the way the window is placed the "ok" and "cancel" buttons cat not be seen nor reached forcing me to move the window manually.
Presentations
Presentations
TextMaker
TextMaker
Steps to reproduce:
1. Start TextMaker (or Presentations).
2. Click the "Create new document" button.
This issue can be reproduced in KDE Plasma 5, Enlightenment 24, FVWM2 and 3, e16, and WindowMaker. This suggests to me this is not an issue with the window manager but TextMaker and Presentations. PlanMaker seems unaffected, the dialog window is big, but it fits inside the screen.
My screen resolution is 1366x768. TexMaker and Presentations window geometry height goes beyond 900.
Re: Over sized New document windows
Thanks for reporting this problem. Please share your sminfo file which you can generate by clicking on '?' > About > Write system information.
lgsl
Post by lgsl »
Here you go
sminfo.txt
(458.29 KiB) Downloaded 3593 times
Thanks for sharing sminfo file. Please follow these steps and check if this resolve your problem :
1. Close all the SoftMaker Office applications.
2. Rename SoftMaker folder to SoftMaker_Old.
3. Then check if this problem occurs again.
4. If yes, please uninstall SoftMaker Office and restart your computer.
5. Download and install a fresh and latest copy of SoftMaker Office.
6. Then check if this problem occurs again and let us know the results.
lgsl
Post by lgsl »
The problem persists.
Thanks for trying the mentioned steps. Our developers team has fixed this problem and the solution will be included in the next service pack of SoftMaker Office. So, you can try after updating SoftMaker Office with new service pack which is coming soon.
