"No Language" not saved
jmarc
Post by jmarc »
When I assign "No Language" to a text or a style (character as well as paragraph) this assignment is not saved in the document.
If I close Text Maker and reopen it with the previous document, all the texts or style I have set to "no language" come back to my default language.
This is not the case with the text declared with "real" languages. I use a language for which I don't have the dictionary, as a workaround. Anyway, the issue should be fixed.
Re: "No Language" not saved
Please check your file format as Word doesn't support "No language", so docx file format will not hold this setting but if you will save your file as TMDX, there will be no problem.
jmarc
Post by jmarc »
Thank you. I noticed that for new documents the feature was working but I did not realised that this was linked to the file format.
