How can I install additional hunspell dictionaries
simwin
Post by simwin »
Can't install this dict -
https://vorboss.dl.sourceforge.net/proj ... 9-ieyo.oxt
or https://extensions.libreoffice.org/asse ... -0.4.5.oxt
Some file is missing... How can I install additional hunspell dictionaries?
Re: How can I install additional hunspell dictionaries
simwin
Post by simwin »
With these dicts there is no problem, but I want to install another hunspell dict from the side - see my first message.
To use should Hunspell dictionaries from any other website you will have to create a compatible SOX file. To do that please follow these steps:
1. Download any other Hunspell SOX file from our website.
2. Unzip it (it is just a ZIP file with a different file extension) using any tool.
3. You need to replace the dictionary files from your downloaded file from other website, edit dict.ini and re-zip it, then rename to .sox.
Now you will be able to import this sox file.
