Wrong system font
Vistaus
Wrong system font
Post by Vistaus »
I just bought and installed SoftMaker Office 2021 and checked the setting "Use system font for menus and dialogs", but it uses some weird Serif font rather than the actual system font. All other apps on my system use the correct font.
How do I fix this?
OS: Deepin 20 (based on Debian 10)
Re: Wrong system font
Thanks for reporting this problem. Please share some screenshots of SoftMaker Office and any system application so that we can compare.
Vistaus
Post by Vistaus »
Here are the system monitor and file manager as an example, which like all other apps use the right font:
https://imgur.com/a/8XIML2u
GTK apps also use the correct font:
And here's SoftMaker Office using the wrong font:
https://imgur.com/a/qdCESXg
I think you pasted one link 3 times here.
Vistaus
Post by Vistaus »
Oh well, even in that one link you can see my actual system font that SoftMaker should be using. You can see the system monitor, Vivaldi and the panel all using the correct system font.
Please share your sminfo file which you can generate by clicking on '?' > About > Write system information.
Vistaus
Post by Vistaus »
Thanks for sharing the sminfo. I have forwarded the details to our development team.
Vistaus
Post by Vistaus »
For some reason, the issue solved itself. Not sure what caused it and what changed, but I'm glad it's solved. Thanks for the support! :)
Thanks for confirmation that your problem is resolved. :thumbsup:
