Check level of Softmaker installed
DWB66
Post by DWB66 »
I want to verify what level of Softmaker is actually installed on my PC. The guidance given is to open up an application such Textmaker, then click on "Help" in the top right corner, then click on "Check for updates". The only reply given is "No updates found".
What does this actually mean?
Re: Check level of Softmaker installed
That means you already have the latest updates installed and there is no more update available for now.
If you want to check the details of which revision is installed please click on Help '?' > About.
