Issue when saving file
Gramps Holland
Post by Gramps Holland »
When I save a file in planmaker I get the message "unable to create backup". It does not appear to impact saving the file but I don't know what it is trying to tell me and frankly it is annoying. Any ideas?
Re: Issue when saving file
Please click on ribbon command File | Options | Backup Tab | Please check this path under "Folder for File versions" and verify that:
1. This folder path is accessible.
2. You have permissions to write files in this folder.
If you are not meeting above two conditions you can change this path also which will resolve this problem for you.
Gramps Holland
Thanks for your help. That resolved the issue.
