Can't exit from completed spellcheck
JohnWasilewski
Post by JohnWasilewski »
This has happened a few times.
After completing a spellcheck (of a 50 page document, which might not be relevant), I have been unable to close the spellchecker.
TM gets stuck in a loop. It displays this dialog/requester,
Code: Select all
CHECK SPELLING
[ ]  From current position
[ ]  Whole document
[OK]   {Cancel]
but when I click 'Cancel', it just re-displays the same dialog. Over and over again.
Interestingly, while I have been typing this report, the document, in the background, seems to have ended the spellcheck on its own because teh dialog has disappeared and I have regained control of the document.
John
Re: Can't exit from completed spellcheck
Thanks for reporting this problem. Please share the associated file of TextMaker 2021 in which you are getting this problem so that we can do further investigation for resolution. Is this problem reproducible or happened once only?
viewtopic.php?f=386&t=20708&p=68540#p68540
JohnWasilewski
Are you quite certain that you have to have a copy of my document? I ask because (1) it is a little troublesome to send it, and (2) I do not think it will be useful to you if I do so. This is why:
  • The fault is not reproducible, even to me in the same document, so you won't manage it either.
  • It happens when I use F7 or Shift-F7, but not every time, just occasionally.
  • After it happened a few minutes ago, and I cleared it, I could not make it happen again in the same place in the same document.
  • I have also experienced the same problem in other documents.
What happened a few minutes ago was similar to what I described before, as follows:
- I selected one word.
- I pressed Shift-F7 and looked at the Thesaurus list of synonyms.
- I clicked 'Close'.
- TM2021 went into an endless loop of
  • TM prompt dialog, 'OK' or 'Cancel'
    I clicked 'Cancel'
    TM looped back to the prompt dialog.
I could not break the loop. I tried clicking 'Cancel' and I tried clicking the red 'close' gadget, but TM kept looping back.
Exactly as before, what broke the loop was when I opened Safari and started to write this report. When I flipped back to TM, the dialog was gone.
Next time it happens, I'll experiment with other possible work-arounds, such as by clicking just on the desktop, or switching to something else, not Safari.
John
Non-reproducible problems are tough... we'll wait for your future comment. Thank you!
JohnWasilewski
It has just happened again.
See screenshot:
No mayor how much I tried to vanquish it, it would NOT go away until I clicked on something that was not in TextMaker, and then it disappeared.
New information:
1. It did not have to be Safari that I clicked on, just somewhere outside texMaker.
2. Once it had gone, I found it difficult to get ANY response from Shift-F7. TM simply ignored Shift-F7 until I had tried it several times, when it did then respond. Perhaps something was still in the process of dying-off and being cleared away in the background.
3. I forgot to mention that, on a recent-version MacBook Pro, Shift-F7 has to be pressed, not as a quick press of Shift-F7, but as a sustained hold of Fn-Shift-F7 (released when it executes). I don't know whether this has any relevance.
In the meantime, we have the workaround I have described.
I don't see how I can help any more with this but I hope I've given enough clues for your developers to track down this errant behaviour in the source code.
John
Thanks, could you please go to "? | About | Write System Info" and send us your sminfo.txt file?
JohnWasilewski
sminfo.txt file just now sent as requested.
J.
Although I couldn't reproduce the issue, I reported it the developers.
Thank you
