Showing a single Comment
xapie128
Post by xapie128 »
Under File > Properties > Options, there's an "Always show comments" (plural, i.e. selecting shows ALL comments). What if I have multiple cells with comments but I only want the comment always displayed on a SINGLE cell? Can I turn on the "show comments" for just a single cell?
Re: Showing a single Comment
To see comments in a single cell there is no need to enable any option, just hover your mouse pointer over that cell and comments will be visible to you.
fernandok
Post by fernandok »
To keep showing all the time... not just when the pointer is on it.
How to do it?
Currently, this is not possible to show one comment only permanently. I have forwarded this improvement suggestion...
