Unable to embed picture in Calculate/Planmaker spreadsheet
andyhornblower
Post by andyhornblower »
I have tried everything I know (including reading the manual!!) to embed pictures within partjcukar spreadsheets - with no success!
The manual confidently states that I need to check the embed/save in spreadsheet box - WHICH IS NOWHERE TO BE FOUND!
I do realise that I'm either being blind, daft or both. BUT, can someone please help me?
Thanks in advance,
Andy Parker
Re: Unable to embed picture in Calculate/Planmaker spreadsheet
Post by Jossi »
Did you try Object > New picture frame... ?
andyhornblower
Hi,
Now solved! (Partially!) - The save in document option is a VERY small checkbox in what, otherwise, looks EXACTLY like a Windows Explorer File popup window! - I have suggested a screenshot in the manual to tech support!
Unfortunately, this does NOT apply to the Android version, and, so far, I have found no way around this! - Any clues?
AndyP
