Long Linux startup time
jhdore
Post by jhdore »
Hi there,
TextMaker 2021 takes well over a minute to start, and shows a grey screen with a spinning 'Busy' cursor. I started it with the -debug option, and this shows up in the tmlog.txt:
[ 2561ms][ 0ms]: comInit: AppFonts
[ 2561ms][ 0ms]: comInit: AppLFile
[ 2561ms][ 0ms]: comInit: Timer
[ 63959ms][ 61398ms]: comInit: Accelerators <---- YIKES!
[ 63959ms][ 0ms]: comInit: History
[ 63961ms][ 2ms]: comInit: appData
[ 63961ms][ 0ms]: spInitCountryInfo(0): ID:2c Date:DMYhmsQ TS:, DS:.
- How can I speed this up?
(Ironic that it's "Accelerators" that slows it down!)
Cheers,
James
Re: Long Linux startup time
Thanks for reporting this problem. I have forwarded the details to our development team for further investigation of this problem.
Please share the complete tmlog.txt file for a better resolution. Also, share your sminfo.txt file which you can generate by clicking on '?' > About > Write system information.
