Full screen slide show
bluffhollow
Post by bluffhollow »
I will be giving a slide presentation over Zoom, and the discussion moderator would like to see the slides take up the entire screen; right now the screen shows vertical black bars on each side of the slides. Is there a way to make the images fill the entire screen?
Re: Full screen slide show
Set the layout either to 4:3 or to 16:9, depending on the aspect ratio required.
bluffhollow
Sorry - could you tell me where I find the setting for that?
Post by Jossi »
In File > Page setup.
bluffhollow
Thanks very much!
Return to “Presentations 2018 for Windows”
