Duplicating a table in Textmaker
AbbyNormal5
Post by AbbyNormal5 »
Hi -
I'm wanting to copy and paste the style of table I already made in a document, but when I paste, it just pastes the text. Is there a different command I'm just not seeing in the ribbon? Many thanks for your thoughts!
Re: Duplicating a table in Textmaker
By default, when you copy a table from one file to another it copies with style.
AbbyNormal5
Sorry, to clarify, I meant trying to duplicate a table within the same document. Only the text gets copied.
Post by Jossi »
With the cursor somewhere in the table, I go to Table > Select > Table. The whole table is selected, and with Ctrl+C, Ctrl+V I can copy and paste it with styles and all.
