Losing Formatting
surian
Losing Formatting
Post by surian »
Every time I disable hyphenation all formatting in Textmaker is lost. Bold, text justification, space between lines, all is lost and I have to format the text again. And the option to not hyphen text doesn't change on menu. It works, but doesn't show on menu that it worked. Please fix these bugs.
Re: Losing Formatting
Thanks for reporting this problem. Please share the associated file of TextMaker 2021 in which you are getting this problem so that we can do further investigation for resolution. Also, share your sminfo file which you can generate by clicking on '?' > About > Write system information.
viewtopic.php?f=389&t=20550&p=68135#p68135
