Fill with picture wrong scaling
ericmarcelo
Post by ericmarcelo »
I created a rectangle with the same aspect ratio as a picture. Then I filled the object with that picture but what I got was only a portion of the picture. The picture was bigger than the rectangle. I tried resizing the picture in the properties dialog box but it's too tedious. Is there a setting that will automatically scale the picture to fill the object so that the whole picture fits inside the object?
Re: Fill with picture wrong scaling
If you want a rectangle around the picture, you can simply insert the picture and put lines and 3D around it from picture properties dialog box. We have many styles and customization there.
Return to “Presentations 2018 for Windows”
