Add 1 presentation to another keeping the format
fd4gzus
Post by fd4gzus »
I've found how to add slides from 1 presentation to another, but when I do, it changes the format of the slides...not just the added presentation slide formats, but if I want to create a slide within the presentation I added slides to, it changes their formatting as well at the base level. There is no keep same format available when copying and pasting.. Never seen this before and dunno how to fix it. PowerPoint didn't do this, so I'm hoping there's a simple fix to it. I have the Office 2021 version.
Thanks.
Re: Add 1 presentation to another keeping the format
Thanks for reporting this problem. Please share the associated files of Presentations in which you are getting this problem with steps to reproduce the problem so that we can do further investigation for resolution.
viewtopic.php?f=384&t=20494&p=67953#p67953
Return to “Presentations 2021 for Windows”
