Showing open workbooks in taskbar
zorgoz
Post by zorgoz »
Is there any way to show all open workbooks in the taskbar not only the active one?
Re: Showing open workbooks in taskbar
Open them in separate windows instead of tabs.
zorgoz
Post by zorgoz »
Ok, but it does open them in tabs by default from system action, is there any way to change this behavior?
Yes, click on ribbon command File | Open | You will see one option "New program window" above open button, check this option and open any file from this open dialog box. Next time onwards whenever you will open any file from open dialog box or directly it will open as new program window.
