Fast numbering list
hatake00
Fast numbering list
Post by hatake00 »
Hello, is there any way to have a fast automatic numbering list? For example, when I will write "1." it would become a list automatically, as it happens in MS Office.
Re: Fast numbering list
There is a faster way, instead of manually typing "1." you have to just click on the numbering button under the paragraph group to toggle numbering on. You can also set up a shortcut key(like Ctrl+1) to toggle numbering from ribbon command File | Customize | Customize ribbon.
hatake00
Post by hatake00 »
When you are writing a lot and not using a mouse at the moment, it's really faster to push an ENTER and then start numbering by inserting "1." then looking for a small numbering button...
SuperTech wrote: Mon Oct 05, 2020 1:01 am You can also set up a shortcut key(like Ctrl+1) to toggle numbering from ribbon command File | Customize | Customize ribbon.
That's why I also informed you about this shortcut key.
hatake00
Post by hatake00 »
You are so stubborn trying to convince me to use another solution and change my habits even though I twice said I don't want to use it. Thumb down. [-X
I have forwarded this request to our product management...
