Solution expanded -- How to open, edit & save files stored in the Cloud, while working with Softmaker
ecbritz
Post by ecbritz »
I would like to use a cloud storage site where I store and if possible create, open, edit and save new files I am working on while using Softmaker Office. Which online storage site(s) or "drives" can be made to behave almost like a regular offline folder, when using Softmaker? How do I open, edit and save files located at an online storage site while using Softmaker Office?
The most important advantages of using MS Office in conjunction Microsoft's OneDrive Cloud storage site are that you can't lose your files through crashes of your computer or through drive failure, and that you can work on your files anywhere and on any other computer as long as you can go online. For this reason it would be great of you can link your Softmaker productivity with an online storage site as well. Advice about this matter would also be great.
Softmaker 2016 & 2018.
Re: How do I create, open, edit and save files stored at a cloud storage site while using Softmaker Office?
Currently, we don't have this integration, but I have forwarded this feature request to our development team. Thanks for your suggestion.
ecbritz
First solution: save to OneDrive while working with a Softmaker Office program
Post by ecbritz »
Thanks SuperTech but I seem to have found a solution.
If you have OneDrive up and going on your Windows 10 computer, you can open, edit and save files directly to OneDrive while using Softmaker Office programs such as Textmaker. You don't need MS Office to utilize OneDrive Cloud file storage.
SAVE FILE TO ONEDRIVE WITH TEXTMAKER: File > Save as > Scroll down the list of folders on the far left side of the "Save as"-screen > Select OneDrive or a subfolder created within OneDrive > Save.
OPEN FILE IN ONEDRIVE WITH TEXTMAKER: File > Open > Scroll down to OneDrive to open a stored file.
The first 5 GB of files are free to store at OneDrive. But you can buy more storage space.
If you open a OneDrive account, you can access your files stored in the Cloud directly by utilizing the OneDrive App. The OneDrive App behaves almost like an offline folder.
ecbritz
Second solution -- Use Box.com and Box Drive app
Post by ecbritz »
The Cloud Storage site Box.com can be used in the same way. Sign up to Box.com . Also install Box Drive at https://www.box.com/resources/downloads . You should now be able to "save to" your folders at Box.com or retrieve your files from Box.com using Softmaker Office programs. See the picture attached to the previous posting. Box.com is shown as an alternative Cloud storage "folder".
Box.com offers 10GB free storage. You can buy more storage space if needed.
In response to SuperTech''s appreciated comments, I would like to say that Softmaker does seem to be geared to integrate with certain Cloud storage sites. But Softmaker does not have its own Cloud storage site, as far as I can see.
ecbritz
Third solution -- Sign up to pCloud & install pCloud Drive
Post by ecbritz »
You can add other Cloud "drives" or "Cloud folders" if you want as much free Cloud storage as possible, or want to try out different Cloud storage sites. I have added pCloud to my list. You have to sign up to pCloud and also download and install the pCloud Drive to make it work. See the attachment.
seasidepb
Re: Solution expanded -- How to open, edit & save files stored in the Cloud, while working with Softmaker
Post by seasidepb »
I have been doing this (using OneDrive) for years. It's a critical function, because I will often be writing away from my desktop on my Surface Go, and I'd rather use OneDrive because it's tightly integrated with Windows.
But lately I've had some frustration. Clearly it's necessary when you stop working on one machine that you give OneDrive time to upload the changed file. I don't know whether it's something to do with OneDrive or the 2021 version of Textmaker, but quite often it will seem that OneDrive has finished doing its thing, so you close down the machine and when you come to open it on the other one the file hasn't updated. You have to go back to the other machine, launch Windows again, let OneDrive do its stuff, and then you can shut it down and the sync will have happened. It's more annoying than disastrous, but it was enough to push me back to giving Word a try again after many years thinking it had just gone to pot.
(I have an Office 365 sub largely because it's the cheapest way to get 1tb of cloud storage, but have resisted using Word for many reasons).
Word seems to work very differently, holding edits in a hidden temporary directory/file, and syncing as you go along. Trouble is that twice now it has lost a significant amount of text in the process. That's clearly much more serious, and has driven me screaming back into the arms of Textmaker (which I've always liked far more - bless its flexible UI).
BTW Textmaker is much better at returning to your last point of editing than Word, which tends to go to the last point you edited on that particular machine.
I realise the problem is more likely to do with OneDrive than Textmaker, but if you have any suggestions about how to force the sync that would be really welcome.
seasidepb
Post by seasidepb »
As a further note, reluctantly I've installed Google Drive alongside OneDrive, and Textmaker files saved there do seem to update between machines as you'd expect. So it looks like a problem specific to OneDrive, though I don't know if Softmaker can do anything about it from its end. It would be great if they could: the benefits of Textmaker over Word are compelling so I'll stick with it but I'd really rather not have dual cloud installations (and OneDrive in most other respects is preferable to Gdrive).
This is purely OneDrive related problem, and you are not the only one who is phasing this problem. If you check on OneDrive forum this is one of the pending problem in the discussion that Windows shouldn't shut down until finishing of Sync.
Currently, the only solution is Shutdown your computer after finishing Synchronization or if you know approximately how much time Synchronization will take you can do delay Shutdown. Means instead of instant shutdown, you can command Windows to shut down after 10 or xyz minutes.
