scripting form controls
Jcrey2255
Post by Jcrey2255 »
I am trying to write basicMaker methods for form control objects placed within a planMaker sheet. Namely control buttons. The idea is to have a user open the worksheet and be able to click the buttons to perform methods that would be automated like choose an item from a drop list and it would filter the worksheet data accordingly, or use buttons to click to change the view using autofilter.
1. Is there a visible(accessible) Property or Object which I can use to point to the control?
2. How do I identify the Form objects on a worksheet so that I may assign scripts to them?
3. Is there a named event handler that I can use to script the button click event? (like On_Click or Status_changed or Mouse_click or ?)
I see that the control has a name variable in the properties dialog but there is no other functionality built into the dialog. Maybe just add a bit of code to look for activation events and allow a script to be assigned to run... [-o<
I would really like to love the software but if I cannot use the form controls with scripts at all.... it would be a major shortcoming. #-o [-X
Re: scripting form controls
Actually, PuchButtons provided in PlanMaker don't trigger any event or you can't attach any code/script with them as mentioned in the PlanMaker manual also as following:
Use the ribbon command Insert | group Objects | Form object | Pushbutton to insert a pushbutton.
Note: In PlanMaker, pushbuttons cannot be used to execute macros or VBA scripts; they are merely present for compatibility with Excel.
Currently, to run a BasicMaker script you can use the "Run script" button which is in the ribbon command File | Scripts group.
You can also use the User-defined button from customizing ribbon options but that will place them in PlanMaker permanently irrespective of file opened.
