Relative position cossref points the wrong way
JohnWasilewski
Post by JohnWasilewski »
TextMaker Professional 2021 (rev S1018.0818) 64bit
Please see my email Thu, 2020-09-03 at 18:52 +0100 with an attached document.
Please see paragraph 33. The cross reference I have entered to Table 1 gives it as 'above', when in fact it is below.
John
Re: Relative position cossref points the wrong way
Thanks for sharing this file and details. It seems there are some changes after entering this cross-reference, please press F9 once which will refresh the references and will make it below. After that, you can save the corrected file.
JohnWasilewski
Yes, I too found it corrected itself. However, please note, I am fairly sure it was incorrect from the moment I set it. It must have assessed the direction from some recent text positions, not the one at the moment of setting it.
Subroutine/function call needed on setting this pointer before computing the direction.
John
