I attach a short Textmaker 2021 document in which the "th" of "23th August" did not (and will not) automatically turn to superscript, after pressing the spacebar. You will see that the "th" of "16th" and the "th" of "24th" in the same short document did automatically turn to superscript. A bug???
After writing the short document, and then exiting Textmaker -- followed by opening the program again -- the "TextMaker Professional 2021 (rev S1018.0818) 64bit" update was announced as having been installed. With this new version, there seems to be no automatic superscripting at all. Perhaps some setting needs adjustment?
Bug discovered, I think. (SOLVED, SEE PREVIOUS THREAD ABOUT THIS MATTER)
- No automatic superscripting.docx
- (12.32 KiB) Downloaded 4404 times
Softmaker 2016 & 2018.
- Contact:
Re: Bug discovered, I think
That's because it would be the 23rd and not the 23th.
Of course! It's 12:14 am at night in Kenya, the only available excuse for this blooper! I'l try the "TextMaker Professional 2021 (rev S1018.0818) 64bit" version again tomorrow ...
