The "If" function is faulty.
PProl
Post by PProl »
The "if" function expects 4 parameters instead of 3. The false branch is not working properly.
Re: The "If" function is faulty.
I checked, and there is a bug in our Hungarian translation. Both IF and IFS were translated as "HA".
We will fix this. The correct function name is HAELSŐIGAZ.
But can you quickly help with this? I need the proper casing. I think it should be HaElsőIgaz. Can you verify this?
PProl
Post by PProl »
Yes, the "HA" function works as "HAELSŐIGAZ".
(The bubble help, on the other hand, belongs to "HA".)
Thx!
Can you check if my way of writing with uppercase and lowercase is correct? I want to write as as HaElsőIgaz
PProl
Post by PProl »
The camel hump is Correct!
But if you need help, the word
"Első”
is unlucky because it means ‘first’ and is not good for writing additional terms! (second/=második/, third/=harmadik/ ...)
I recommend:
"(Feltétel; HaIgaz)"
or numbering:
"(Teszt1; Eredmény1; Teszt2; Eredmény2)"
OR
"(1Feltétel; 1HaIgaz; 2Feltétel; 2HaIgaz)"
