Project explorer pane
TonyDaly
Post by TonyDaly »
Softmaker Office 2021 is really good; well worth the upgrade from 2018. I really like the fact that it does things differently from MS Word, which seems to be making life more and more difficult for its users.
One thing that I would really like to see in Softmaker that would separate it further from mainstream alternatives is the use of a project explorer pane. This would be similar to that used by text editors such as Atom and Sublime text.
It would enable users to see related documents in a tree-like view. I think Scrivener also uses this concept. This should be available across all apps, not just Textmaker.
Having a project pane would really speed up workflow because supporting docs/figures etc would be much easier to access.
Keep up the good work.
Re: Project explorer pane
Thanks for your suggestion. I have forwarded this request to our product management...
