Printing with TextMaker on Mac
ADZ20
Post by ADZ20 »
TextMaker is not picking up the network printer for this application. Mac apps do see the printer and can print. PlanMaker 2021 and Presentations also see the printer and can print. What is the resolution for this?
Re: Printing with TextMaker on Mac
Post by Jossi »
Does it work when you choose the Apple Print Dialog first and your network printer from there?
ADZ20
Post by ADZ20 »
In TextMaker 2021, Selecting FILE - PRINT brings up the Print window. Under Print Devices, the Printer: option shows no names. Selecting its drop down shows no printers and no Apple Print Dialog [System] listing. In PlanMaker, both the printer and the Apple Print Dialog [System] appear.
Please share the screenshot of TextMaker and PlanMaker which shows this problem where you can see the printers in PlanMaker but not in TextMaker.
ADZ20
Post by ADZ20 »
Here are Print Dialog screen prints from TextMaker & PlanMaker
PlanMaker also lists the Apple Print Dialog option
TextMaker screen
TextMaker screen
PlanMaker screen
PlanMaker screen
ADZ20
Post by ADZ20 »
Problem is resolved.
I had another issue with User Interface selection. It's fix (rename Documents/SoftMaker folder) also fixed this problem. All set now. Thanks.
