Bullets being converted to clapperboard
AllanWhoops
Post by AllanWhoops »
Hi,
If I open a Word document in Textmaker, the bullets all get converted to clapper boards. It looks as though this is a font substitution issue with the original bullet's character and font not being found or the default Textmaker font for bullets being different to the original Word document.
Is there a work around please?
many thanks,
Allan
Re: Bullets being converted to clapperboard
Thanks for reporting this problem. Please share the associated file in which you are getting this problem so that we can do further investigation for resolution.
https://forum.softmaker.com/viewtopic.p ... 248#p67248
Thanks for sharing the file and screenshots. I opened the file and found that bullets are showing correctly in TextMaker at my end. Please check the screenshot and your file saved by me, I sent them by email.
Please reinstall SoftMaker Office and check Or you can also try these steps if you don't have any specific settings or documents saved in SoftMaker Folder:
1. Close all SoftMaker applications like TextMaker/PlanMaker.
2. Rename Documents/SoftMaker folder.
3. Try to open this file in TextMaker and see if that resolves your problem.
