Form feilds fonts
zackf
Form feilds fonts
Post by zackf »
I am creating forms and am having a hard time getting the test fields to be the fonts I want. I try to highlight the field and change the font the way I want via the home tab, but it only works if you click into the field just the right way.
Is there a way to ensure that any text within a text field will be a certain font?
Re: Form feilds fonts
Post by Jossi »
Set the cursor inside the field, press Ctrl+A to select all, then change the font.
zackf
Post by zackf »
nice =D>
