UNDO function dead when entering/editing text strings
JohnWasilewski
Post by JohnWasilewski »
PlanMaker Professional 2021 (rev S1016.0624) 64bit
When editing text entries in cells, Ctrl-Z fails to undo. It has no effect at all.
Also, the menu entry for UNDO is ghosted.
We DO need to be able to use Ctrl-Z and Ctrl-Y when editing text string cell data.
John
Last edited by JohnWasilewski on Mon Jul 20, 2020 5:13 pm, edited 1 time in total.
Re: UNDO function dead when entering/editing test strings
I tried to reproduce this issue with 250 character text in PlanMaker cell and was able to perform Undo/Redo without any problem.
Please share the associated file of PlanMaker 2021 in which you are getting this problem so that we can do further investigation for resolution.
If you want to send it to us privately, please send us an e-mail to the forum[at]softmaker.de
https://forum.softmaker.com/viewtopic.php?f=390&t=20284
JohnWasilewski
Re: UNDO function dead when entering/editing text strings
SENT.
See email Mon, 2020-07-20 at GMT 14:15 +0100
Put the cursor anywhere in a text string in column C.
Type, for example, 'asdf'. It flows into teh text where entered.
Press Ctrl-Z.
Nothing happens. 'asdf' is still there.
Well, that's how it is here at least.
I'll also email my sminfo.txt file, in case you need it.
John
To do Undo/Redo in PlanMaker you have to click outside the cell to exit from Cell edit mode. I have forwarded this as a feature request to our development team.
