Inserting a database list
AshleyDennison
Post by AshleyDennison »
Hi, I want to insert a list from a sqlite database into a textmaker document.
When i select the database using the LIST/LABEL option from the Mailings menu, it is truncating LONGTEXT entries.
If i use the normal mail merge, i can set the option to choose LONGTEXT for the field in question, which then works, although obviously I only get one record per page which is not what i need.
Is there a way to fix this? Or alternately, have the normal mail merge put all the merged fields into one continuous page.
Re: Inserting a database list
Thanks for reporting this problem. Please share associated files and steps to reproduce the problem you are getting in TextMaker 2021 so that we can do further investigation for resolution.
https://forum.softmaker.com/viewtopic.p ... 101#p67101
AshleyDennison
Email sent with SQLite database and corresponding textmaker document.
Thanks for sharing the files. I have forwarded the details to our development team.
