Word Count function
RANVAN
Word Count function
Post by RANVAN »
Hello. I am an author and new to this program. I need to be able to keep a current word count when I write. I would appreciate it if you can tell me where or how to turn this function on. Thank you.
Re: Word Count function
To enable this feature please follow these steps:
1. On the bottom of TextMaker, you will see the status bar. Right-click on the status bar and select Customize there.
2. This will open the "Customize user interface" dialog.
3. In quick search please type "count words", this will show you one command in the list "Count words".
4. Select it and then press arrows which ware towards right " >>".
5. Click close, this will add the "Count Words" feature in your status bar.
6. You can move this command up/down in the same "Customize user interface" dialog.
Return to “TextMaker 2018 for Mac”
