Object Frame issue
jmarc
Object Frame issue
Post by jmarc »
There is an associated anchor to object frames.
This anchor is precisely anchored wit lines, that means it is always related to the same text line, even if we remove or add some text lines before it, thst is good. Unfortunately, the object frame associated with this anchor does not move with it. The aftermath of this, that any "floating" objet or image cannot be anchored with text. That means if we modify the text before by adding or removing lines, spaces, the image is not well located.
Re: Object Frame issue
If you are using an embedded object that will move with the anchored text.
For an object frame, you can simply right-click on the object > Click on Properties > Under Layout tab and Object section you can enable/check "Move with text" option afterwards that object will also move with the anchored text.
