email documents
niknik1971
email documents
Post by niknik1971 »
I am new to Soft Office 2021 as i have only just recently purchased it.
One of the features i would like to use, but do not know how to set up is the email feature.
The email app I use is Mailspring.
I do not know what needs to be typed in the command box?
As you can probably tell I am a bit of a newbe when it comes to Linux
Any help or advice would be great.
NIK
Re: email documents
When you will click on the send button this command field is automatically filled according to the entries, so there is no need to change anything there.
