Does Presentations use Text Styles?
dhermosillo
Post by dhermosillo »
One really annoying and time consuming issue with PowerPoint is that is does not use text styles.
So, if there are any major style changes, the user has to painstakingly comb through the slides one by one making changes.
Does Presentations 2021 use styles?
Re: Does Presentations use Text Styles?
No, Presentations doesn't use Text Styles but it uses Slide designs which you can create and edit from ribbon command View | Slide master as per your requirements. So, if you have major customization in text formatting you can create a new slide design with these customizations.
SuperTech wrote: Wed Jun 24, 2020 8:24 am No, Presentations doesn't use Text Styles but it uses Slide designs which you can create and edit from ribbon command View | Slide master as per your requirements.
What is the comparable command for those of us who use the classic menu rather than the ribbon?
For classic menu command is View > Master > Slide Master.
Return to “Presentations 2021 for Windows”
