Textmaker process using 6GB memory and getting killed by OOM
mgrinsven
Post by mgrinsven »
Just had Textmaker being killed by OOM because it was using 6GB of memeory:
Code: Select all
Jun 20 18:53:34 elitebook textmaker-2021.desktop[3869]: Killed
Jun 20 18:53:34 elitebook systemd[1727]: gnome-launched-textmaker-2021.desktop-3869.scope: Succeeded.
Jun 20 18:53:34 elitebook kernel: [27930.905656] [   3869]  1000  3869      652        0    49152       23             0 textmaker21
Jun 20 18:53:34 elitebook kernel: [27930.905658] [   3872]  1000  3872  1660523  1371523 12517376   126134             0 textmaker
Jun 20 18:53:34 elitebook kernel: [27930.905777] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),cpuset=/,mems_allowed=0,global_oom,task_memcg=/user.slice/user-1000.slice/user@1000.service,task=textmaker,pid=3872,uid=1000
Jun 20 18:53:34 elitebook kernel: [27930.905797] Out of memory: Killed process 3872 (textmaker) total-vm:6642092kB, anon-rss:5477656kB, file-rss:0kB, shmem-rss:8436kB, UID:1000 pgtables:12224kB oom_score_adj:0
Jun 20 18:53:34 elitebook kernel: [27931.234331] oom_reaper: reaped process 3872 (textmaker), now anon-rss:0kB, file-rss:0kB, shmem-rss:8436kB
J
The document that was loaded contains only 3.5 pages of text with 2 small pictures. The file size of that document is 81.9 KB. The document does contain citations using the Zotero plug-in and i managed to add the bibliography without Textmaker crashing or using 100% CPU.
Don't know if it was related, but there is definitely some memory leaking going on there...
Re: Textmaker process using 6GB memory and getting killed by OOM
Thanks for reporting this problem. Please share the associated file of TextMaker 2021 in which you are getting this problem so that we can do further investigation for resolution. Also, share your sminfo file which you can generate by clicking on '?' > About > Write system information.
viewtopic.php?f=389&t=20180&p=66728#p66728
