TextMaker 2021 constant crashes
campingcheese
Post by campingcheese »
Hey! I've started using TextMaker 2021 (Windows) yesterday and I met with constant crashes while typing or while changing font. On the latest one, Visual Studio said:
Unhandled exception at 0x00007FFA9353759F (ntdll.dll) in TextMaker.exe: 0xC0000374: Egy halom sérült (parameters: 0x00007FFA935986B0). occurred
(The Hungarian error message "Egy halom sérült" means something like "a heap is corrupt")
Re: TextMaker 2021 constant crashes
Thanks for reporting this problem. Did you send the crash report when TextMaker ask to send? Is this the same email ID which you are using in forum for sending the crash report also?
